RCU Forums - View Single Post - Torque and P factor, why do we continually confuse them?
Old 11-22-2011 | 10:37 PM
  #78
Jet_Plane
Default RE: Torque and P factor, why do we continually confuse them?
ORIGINAL: rmh
4.5 degrees offset?
That is a BUNCH!
The model is a Precision Aerobatics Ultimate AMR. It comes stock with 3Deg right thrust but when doing the standard vertical up-line test i consistently had the model yawing away left soI added an extra shim that took the right thrust to about 4.5deg (give ar take half a degree). She now goes vertical without any use of rudder. Increased right thrust also sorted out other areas such as a slight sideways drift through consecutive loops, now eliminated. CG is spot of by the way.
It does swing a 14" prop which is pretty huge for a 40" span model so that probably explains the need for more right thrust than usual. It doesn't have any down thrust.
***Edited due to my stupidity***
