RE: stuck piston ring
So I assume that the ring is now free due to the compression rise?
The best penetrating solution that I have ever used is a 50/50 mix of ATF and acetone and is what a lot of old time mechanics use.
Cheap as chips and works fantastically. Just soak for 24 hours, remove and wiggle or tap - repeat until free.
