RCU Forums - View Single Post - DA 100 Carb problems
Old 11-24-2011 | 09:33 PM
Super08's Avatar
Super08
Default RE: DA 100 Carb problems
Chances are the carb is dry as pointed out if it hadn't run since 2005. The new carb will be dry as well. Take the cover off with the 4 screws and fill it up with gas and put the cover back on, then do the same on the side with the single large screw. That is the side with the diaphragm that pumps the fuel.
