RE: Foil question
Ok, did some more sanding. I can't lose the orange peel without sanding through the rivets. is this normal? On bigger planes, do you just sand around most of the rivets so you don't go too far? I'm using 3200-4000 grit sand paper and still going through. On the finer grit stuff, i can sand for a long time, but I don't really ever get rid of the orange peel.
Somebody explain what i'm doing wrong. [:@]
