RE: lawn darted brand new 50cc
I am curious too as I am a A9 user too. I have flown mine with the 9 and 7 channel receivers in glow powered pylon airplanes, electric Pattern airplanes, 50cc gasser and molded sailplanes. Not any issues with any of the setups. The questions I have are:
Why the 3 battery setup? What batteries and were regulators used?
What RX was used and how were the antennas orented?
What ingnition was used and where were the batteries placement in relation to the ignition?
What range check was used?
Did you voltage check the batteries with a 1 amp load?
Why did you not set up the fail safe? If a lock out had occured and the failsafe was set correctly the controls would have gone to nuetral and the looping would not have occured. If you had the failsafe set correctly then what you described was a power loss.
