RE: Need some ideas on putting balsa on foam wings.
Morning CG. Grandson doing well. Said only 63 more days but who's counting. I know the Dave Brown product you have to work pretty quick, once it touches it's stuck. Afraid with this big wing if everything is not just so, then you end up with a mess. When you use the slow cure epoxy how are you holding the skin down. BTW Lost 53lbs. Getting down to playing weight.
