RE: Need some ideas on putting balsa on foam wings.
Hi Irish.
WOW!! What did you do to lose the weight? I need to shed about the same amount.
His instructions call for the slow cure epoxy followed by the, I believe they call them the "shucks". The foam that remains from the large block that the wing blanks were cut from. He puts these down on a long flat table top, puts the wings with the skins set, then sandwiches the wing core within these "shucks". (I hope that's right.. the name that is). Then he puts a straight plank over that and then about 50 pounds of bricks on top of the plank. He said the more weight the better. Then he leaves it set up for a day before he removes everything.
Dick.
