RCU Forums - View Single Post - Baseline settings Nitro
Old 11-27-2011 | 05:55 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: Baseline settings Nitro
ORIGINAL: Terryh6336
[font=''Verdana''][/font]Ok here are the facts. This is a Direct Connection .40 two stroke. It has both needle valves no airbleed. I am running a Fox long glow plug and 15% Wildcat with a small amount of castor oil.
OK now we are cooking, I suspect it is a rebranded double needle SC. Everything above is appropriate. First run the main needle valve all the way out and turn the midrange screw to where it is flush with the rotating barrel. Now close the throttle completely and screw the main needle valve back in till it stops. Back the needle out two and one half turns and these should be good rich starting positions.
Now after starting it will be rich and not likely to take any throttling so you lean the main needle a little at a time untill you can gradually open the throttle completely without the engine dying.
The next steps are what is called pinch tuning and there are variations of the technique. This technique is not often taught and seldom seen on these forums. It is a very effective method and well worth learning and practice by anyone operating glow two strokes. It is not an effective method for glow four strokes except possibley setting the low range.
Like Kenh spoke of above after you have leaned the main needle enough to open the throttle fully it will likely still be to rich. Do a rapid pinch and quickly let go of the fuel inlet line and as mentioned if it instantly wants to stop the engine then you need to back off the needle a click or two then pinch agine and keep doing this untill the engine will display an almost imperceptible momentary increase in rpm. This will be very close to that sweet spot. If at full throttle at the pinch it gain a lot of rpm then you are still to rich and need to run the needle valve in.
Now to move on to the low range needle and we have the engine running well at full throttle. Let the engine move to a low idle speed and let it run for at least about 15 seconds or more then open the throttle smoothly without stop to full if the engine stops immediatly the low range is too lean and it should be opened slightly (no more than a 1 eighth turn of a conventional double needle carb).
The next situation and by far the most common is when you open the throttle smartly from idle is, there will be much stammering but still runs eventually going to full throttle. This is a situation where the midrange is to rich and that little barrel mid range needle screw needs to be turned in slightly no more than an eighth at a time then check agine by the throttle opening.
The high speed setting and the low speed setting are closely interelated so after setting the high speed and low speed it may well be neccessary to do the high speed agine after setting the low speed (most often just a quick pinch to check and just a click leaner or richer.
Some folks and posters here suggest a little different form of mid range pinch setting and that is fine but the full system I outlined above has held me in good stead for a lot of years and I teach it to all my students who seem to become excellent engine tuners.
John
