RE: Need some ideas on putting balsa on foam wings.
Ditto on the slow set epoxy. If you do it correctly, nothing is near as strong or as light. It is a little more work than some methods, but the results are more than worth it.Spread the glue as thin as possible. Vacuum bagging is the best as it draws out excess glue, but weights work also.
