RCU Forums - View Single Post - Adjusting Prop Depth.
Old 08-24-2003 | 02:57 AM
Ron Olson's Avatar
Ron Olson
Default Adjusting Prop Depth.
I'd start it slightly above the bottom of the sponsons. If you have a leaf type Diningroom table, open it up enough to let the lower unit hang through it or use a board with a slot cut into it. Anyway, adjust the motor so that the top of the skeg is just above the table. Tunnel hulls vary on their setups a little, but this should put you in the neighborhood.
