RCU Forums - View Single Post - DANGER ALERT Dubro Cat. No. 913 "HD Adjustable Control Horn (.91 & above)
Old 11-28-2011 | 07:19 AM
spaceworm
Default RE: DANGER ALERT Dubro Cat. No. 913
ORIGINAL: Pull Up Now!
... Otherwise, it wouldn't occur to people to size the hole so tight.
Dubro say to drill a 5/32 inch hole. Is that the hole size you drilled? Also a hardwood insert would would minimize if not eliminate the problem as it allows the hardware to be sufficiently tightened and would not compress to permit slipping. JMHO.
Sincerely, Richard
