RCU Forums - View Single Post - Need some ideas on putting balsa on foam wings.
Old 11-28-2011 | 08:05 AM
  #39
All Day Dan's Avatar
All Day Dan
Default RE: Need some ideas on putting balsa on foam wings.
Gorish, Put the leading edge and trailing edge on after the balsa skins are bonded to the foam. This will help to shape them properly. Also, use a flat block of 320 sandpaper to level out any imperfections in the foam prior to applying the epoxy and do this carefully not to distort the airfoil. Dan
