RE: mcculloch 32cc timing ?
If the engine has electronic ignition then you CAN adjust the timing, ideal would be 30deg BTDC. If its on the magneto then the timing is fixed at around 24 deg BTDC. If you could make an adjustable timing bracket for the coil then you would also set it for 30 deg.
