RCU Forums - View Single Post - Nuance
Thread: Nuance
Old 11-28-2011 | 11:52 AM
shannah
Default RE: Nuance
I've gone back and forth on the tail servo. I really like having the direct coupled rudder servo. I've had that on my IMAC planes and on my Passport and Visa. I'm a fan of it. I really don't like to mess around with pull-pull. But, I'm a bit concerned with CG. The plane is set up for the tail mounted rudder servo and it looks like it would be pretty easy to install it. Maybe I'll try that and see if it can work out. If not, then I'll go pull-pull. Its easy enough to do either way.
As for finish, you'll be happy. I was just pointing out the nits. All minor stuff. Its a good looking airplane.
