TOC Laser
I have been following the Classic TOC Builds that Rusty and other have been doing and decided that my 33%Laser qualifies. Not wanting to jump on his thread with another build I'm going to do my build here. I do welcome any and all comments, suggestions. I am actually building two Lasers with the second one being put up for sale upon completion of the frame up. Gotta pay for an engine and servos somehow right? I have the Fuses all framed up at this point. The gear is CF and was found on fleabay. I have one set of glass parts layed up and will start the second set later tonight. I have decided to go with foam airfouled tail section. There was lots of debate on the Aerodynamics forum if this was going to enhance performance or not. I guess we will find out. The thickness of the tail section will only be 3/4" at it's thickest so the tail wires may still be needed or I will put in a CF spar to get them srtong enough. The Goal weight is 16 lbs and as of now the power choice is a DLE 55 and canister. Here are a couple of pics along with a couple of the one I lost this spring.
