RCU Forums - View Single Post - Nuance
Thread: Nuance
Old 11-28-2011 | 10:09 PM
  #33
shannah
Default RE: Nuance
Hi Jarvis
This has a different setup than the monolog. The tray can be moved to where you want it. So you can check CG then fix it in position. I usually make my own trays out of glass/nomex but I'll use the one supplied. It looks OK. You should always anchor the battery tray well. That's a lot of weight under G-Load. I usually use Aeropoxy.
