ORIGINAL: CellTech
Whoa! I see the kadet senior barf is now listed for three hundred bucks plus shipping surcharges. My conclusion is Sign has gone insane. I didn't realize the value of the greenback is now almost worthless. Perhaps oriental laborunion strikes are the culprit. Me hopes bars will go away and the kits will make a comeback
Check this one out, it is from Nitroplanes $89.95. They call it super Senior 60. $300 for a Kadet Senior is way too much. they want to recoup in too short a period of time...
Top quality balsa and plywood construction!
Specs
Wing Span: 80.3 in / 2040 mm
Wing Area: 1225 sq in / 79.5 sq.dm
Fuselage Length: 64.5 in / 1640 mm
Flying Weight: 6.0 lb / 2800 g
Requirements
Radio Required: 4 channels 5servos
Engine Required: 2c 0.61- 0.75 cu in
Notes
Float is sold separately. If you like float planes, this plane is worth the upgrade!
Gerry
