RE: Lipos in parallel ?
I have been searching for information on the limiting factors for wiring LiPo's in parallel, to no avail.<div>Basically, I want to wire up to four (4) same brand, type, capacity batteries together in parallel for a project. Thunder Power 6G 3300, 6S</div><div><span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); ">My electric motor will consume up to 59 Amps max, and I plan to use a 77A speed control, but in reality I am assuming a continuous consumption of 25 Amps.</span></div><div><span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); ">
</span></div><div><span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.296875); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); ">Am I misguided here?</span></div><div>
</div><div>Maybe my problem has to do with weak understanding of advanced LiPo usage.</div><div>My project is to fit a Senior Telemaster with this much capacity to get beyond 1 hour flight time. I picked this setup because the combined weight allows me to get as much capacity as possible for the least weight addition. Any recommendations on accomplishing this?</div>
