Uhmmm,, william,,
You sorta left one one tinsey winsey little ingredient of Lateral
balance .. Torsional rotation... This has to be compensated for
as well.. Thankfully, R/C is effected less by it.. Well, probably,
more easy to correct would be a better way to put it..
For those who may ask, torsional rotation is when too much
power is applied causing aircraft to rotate <axial / lateral >..
This is why some manuvers are better done in one direction
than the other..
