RCU Forums - View Single Post - Heads up elevator failure JetLegent Hawk
Old 12-01-2011 | 05:40 AM
Miltiadis
Default RE: Heads up elevator failure JetLegent Hawk
I have hear two other cases with the same problem and result...
the problem, as they told me, was that the two Anti Rotation Pins werent secured into the wood work, which was light balsa (not adequate enough for the elevator), very little glue on any joint has results in the 8mm Shaft twisitng out of the stab structure.
hope this help you understand what went wrong...
Regards
Miltiadis
