RCU Forums - View Single Post - Replacing Piston Rings
Old 12-01-2011 | 08:05 AM
All Day Dan's Avatar
All Day Dan
Default RE: Replacing Piston Rings
w8ye, Should Bowman change his little instruction sheet to take into consideration the cylinders that are lined. I used 400 grit paper on mine. After a couple of flights the compression is very high. I hate to think that I trashed the cylinder. Those things are expensive, and worse, may not be avaiable any more. Dan.
