RCU Forums - View Single Post - Adding winglets to ARF wingtips
Old 12-01-2011 | 01:38 PM
  #31
pimmnz
Default RE: Adding winglets to ARF wingtips
There is only one more 'safe' way to loose weight with this ARF...remove the engine, ignition module and battery, and replace it with the comparable glow motor. Then you move the tail mounted servos to the cabin area, and maybe rebuild the tail surfaces, to rebalance. There really isn't any other thing you can reasonably do to remove enough weight to make a difference.
Evan, WB #12.
