RCU Forums - View Single Post - Gas engine igntion on receiver battery?
Old 12-01-2011 | 02:59 PM
aussiesteve's Avatar
aussiesteve
Default RE: Gas engine igntion on receiver battery?
It can be done but you must use an electronic filter if you do so.
The only one of those that I use nowadays is the Tech Aero unit. there are a couple of others around but I have not had much success with them.
[link]http://www.tech-aero.net/ultra-ibec[/link]
What Voltage does your ignition require? If it requires more than 6 volts the Tech Aero unit is the only one I have found that will supply it reliably to the ignition.
If it is a simple "4 cell pack" requirement, then the weight saving is pretty negligible.
Even 2.4 can suffer from intereference. Don't ever rely on it to shroud a poor build or installation or product.
