RCU Forums - View Single Post - New HOW TO Posted: How to Install Robart Hinge Points
Old 12-01-2011 | 05:06 PM
  #62
skeeter_ca's Avatar
skeeter_ca
Default RE: New HOW TO Posted: How to Install Robart Hinge Points
Prior to gluing can the hinge be installed and removed as needed during building of the model and to check for proper alignment or does this widen to hole to much?
Is the hinge pin installed mostly flush with the surface or does it stick out some so as to pivot the control surface around the edge?
skeeter
