RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 12-01-2011 | 05:36 PM
  #73
MTK
Default RE: OS 33GT Gasoline Engine for Pattern
Here's the Mintor 38 installation. Note the DLE CDI unit. It runs the Mintor just fine. Also note the two servos, top is throttle and bottom is choke
The other thing of note is that part of the carb is actually inside the soft mount. The firewall has a hole in it to accommodate better breathing. That also allows me to install a foam insert behind the firewall to help reduce intake noise a little and filter the air
ID:	1693968   Click image for larger version
