ORIGINAL: rcklingaman
One this I was curious about after I had a look over on the Savage XS is the battery box isn't water proof. If you ran this through water or puddles at all isn't there a risk of water getting into the deans connector joint and shorting it out?
Also had a question on tightening the slipper have you guys found that it responds best with it tightened down? or loosened a little?
I put the deans together and leave them out of the battery box.
