RCU Forums - View Single Post - Gas engine igntion on receiver battery?
Old 12-03-2011 | 11:02 AM
raydar
Default RE: Gas engine igntion on receiver battery?
A basic optical kill switch will NOT seperate your ignition from your receiver if you are using one battery, ahicks said above that he uses one battery with a opto kill im not sure what unit he is using but a standard rexel opto will not seperate a ignition from a rx using a one battery set up. Perhaps he can clarify.
