RCU Forums - View Single Post - Heads up elevator failure JetLegent Hawk
Old 12-03-2011 | 01:26 PM
  #73
kordi
Default RE: Heads up elevator failure JetLegent Hawk
ORIGINAL: paulsf86
The Jet Legend T45 is designed for 12 to 18 lb thrust per the manual published on the Jet Legend web site. A 31lb thrust turbine is just asking for trouble. In no way is the airframe designed for such a power plant. If no one was hurt in the accident, you were lucky.
Paul S
Paul S,
<style type="text/css">p { margin-bottom: 0.08in; }</style><p style="margin-bottom: 0in;">If your are talking about my plane that crashed it was flying on a Kingtech K80 as I wrote in my first post wich gives max 18 lb of thrust in the limits of what the airplane manufacturer suggests.</p><p style="margin-bottom: 0in;">Were did you see the 31 lbs of thrust</p>
