RCU Forums - View Single Post - E-starter hinges
Old 08-24-2003 | 06:07 PM
Peter Khor
Default E-starter hinges
?!? fwiw I've used the supplied hinges and glue on ~10 GWS planes with no problems, a couple of pointers:
* the E-Starter foam is known to be a little softer than all other GWS kits.
* the supplied glue will no melt foam; it is a contact cement fwiw.
* make sure you use a sharp #11 or what ever knife you use to cut out the control surfaces and slotting the hinges, and don't rush.
* test fit the hinges before applying any glue.
* foam safe CA can also be used to install the hinges.
* the plane flys very well with stock setup.
