RE: 16X8 or 18X10 Biela Wide Blade? RCV 120SP
Mimoore67, What ever happened.. I want to do the 4 bladed also on my F4U what static thrust and rpm did you get.
Jens, what did you come up with.
It seems static thrust on these engines cant use "normal" 4 stroke static thrusts to compare.. being such a different animal.. this is really necessary to see what has worked best in the past.
Thanks, Nickel
