basic principles of flight
stoned-X,
The pressure at the leading edge will be higher. I suspect an ellipse will have a higher lift coefficient than a flat plate because the curvature of the leading edge and top surface of the ellipse will allow the ellipse to stall at a higher angle of attack than a flat plate. If the ellipse is very fat though, it will have a lower lift coefficient than a flat plate.
banktoturn
