RE: Nitro Planes CMP P28 Piper Arrow ARF
Let's work it out...
That's a 4000mAh 20C rated pack with a rated 30C burst.
So assuming 20C x 4000mA, that pack can sustain 80A @ 14.8v
80A x 14.8v = 1184 watts.... so you have plenty of overhead there.
Let's assume that you only run the plane @ 15C most of the time.
15C x 80A = 888 watts.
So if you run the motor at max capacity ( full throttle ) ALL of the time, your pack should remain quite cool.
Normally you'll only need 70-78% throttle throughout your flights, so you'll get good runtimes and a long pack life.
