ORIGINAL: Dave Wilshere
Is the wing symmetrical?
If the glue is on the line you can cut either side and sand off the ridge. The wire will stop at the glue no matter what you use in my experience!
Dave Wilshere
Yes it is. maybe then I can put the glue line on on the center line of the rib. Is that kinda what you are suggesting? I think that might work. OK that make sense to me. Now what kind of glue should I use to put the two pieces of foam together? So I guess I will be working with a 4" piece of foam when I am ready to cut.
