RE: Just a question
I would probably take High Plains suggestion. Use a weak contact adhesive while cutting the wing, then come back with foam CA or UHU to permanantly glue the parts together. I've found UHU film & foil to be the best foam glue so far. It doesn't get brittle like CA, stays slightly flexible.
