RCU Forums - View Single Post - Estimate flight time given RX battery size and servos
Old 12-09-2011 | 02:31 PM
  #52
rctech2k7's Avatar
rctech2k7
Default RE: Estimate flight time given RX battery size and servos
Nice point raptureboy.
mranga - Let us estimate your flying time based on your servo and battery data.
Total Average Servo Amp = 2 x 0.25 + 3 x 0.10 = 0.80 A
time = 1.0 Ah * 80% / 0.8 A = 1 hour or 60 minutes
Fully charge your battery and fully dicharge it with watt meter connected, make sure you got 1000mAh if not update my calculation.
After your first flight on a fully charge battery, discharge your battery remaining capacity with wattmeter connected and subtract that to fully charge capacity and you'll get mAh per flight. Divided by the first flying time in hours, you'll get actual average current for your plane.
If you fly 10 minutes per flight, you should get 6-flights per cycle.
