RCU Forums - View Single Post - Balsa USA Fokker DRI 1/4 scale
Thread
12-11-2011, 10:21 AM
47
WacoNut
RE: Balsa USA Fokker DR1 1/4 scale
Middle Wing progress:
I trimmed the L/E sheeting and rough sanded. Installed the top center section sheeting as well as closed in the trailing edge of the center section with 3/32 sheeting.
You will see by the attached picure of the L/E how tight and clean the joint is where the sheeting meets the inner L/E. I will give the center section sheeting a rough sanding then start adding the cap strips.
Later!!
Anthony
Reply
Like
WacoNut
View Public Profile
Send a private message to WacoNut
Find More Posts by WacoNut
View iTrader Profile
