RCU Forums - View Single Post - Phoenix 8 Help
Old 12-12-2011 | 01:47 PM
MMcConville
Default RE: Phoenix 8 Help
The amount you prop up the tip is completely dependent on the airfoil thickness root and tip. It will be different for every airplane. Regardless of how its done, if the TE is straight when viewed from the rear (also meand LE straight when viewed from the front then there is zero dihedral.
My point is that this isnt ideal for the P8. It needs some dihedral to eliminate roll couple.
