RE: Seagull Spacewalker II 120 Arf
OK RJ-
Perhaps this will help
This is for carrying purposes only (for a wing bag)
I need the dimension of one of the two wings not mounted.
I would like the dimension from the wing tip to the edge of the wing where it meets the fuselage.
I would like the dimension of the wing at the fuselage side from wing leading edge to wing trailing edge.
I would like the dimension of the wing at the tip from wing leading edge to wing trailing edge.
I do not need precise dimensions within 1/2 inch would be fine.
Thanks-
Larry
