ORIGINAL: kordi
<div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 9pt''>[img][/img]Hi Jeff,
</span><span style=''line-height: 115%; font-size: 9pt''>Here is the pictures from the elevator that failed.</span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 9pt''>I am very sorry to see that a manufacturer like jet legend will not stand up for his plane and will not replace the problematic construction but blame others.</span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 9pt''>I hope that the other pilots here can see the balsa block that is so soft that can be distorted with my finger nail.</span></div><div style=''margin: 0in 0in 10pt''><span style=''line-height: 115%; font-size: 9pt''>And you can see the wood split clean were the pin were.
[img][/img]
http://img708.imageshack.us/img708/9335/11122011225.jpg
</span></div>
JL should replace the kit on this - bare min. I can't believe they would use balsa there. I'm starting to wonder if my GJC-JL F-16 (which hasn't been maidened yet) is going to have the same issues. I know no one has reported this issues but if what is to say they they don't use the same type of construction?
