glow engine problem
It could be just congealed castor oil. Could be that they were that way before the moisture and you didn't think to check it till after the moisture problem. I so you could heat it up with a heat gun and try to turn it over. If that doesn't work, put some fuel in the cylinder through the glow plug hole and carb. Let it soak for a while and then try to turn it over.
