filler
I use light spackling compound. It is a latex product, It drys fast if laid on in thin coats (1/8" or less) It weighs virtually nothing. It is super fast sanding. I build it up to shape sand to a finish and polyurethene coat it. The poly makes a tougher surface. The only drawback I found is that if you overheat it when covering, it will melt.
