Shaun
Here are my edits…
I added some points for traciability
Purchase Agreement
All newly constructed Ready-to-Fly or Almost-Ready-to-Fly remotely-controlled model aircraft intended for use with turbine engines
shall be assigned a unique airframe serial number; each critical component shall be marked with the unique airframe serial number and shall be shipped with the following required photo documentation:
1. Clear color photos of main wing internal construction prior to installation of the sheeting/skin (showing spars, ribs, hard-points, hinge-blocks, landing gear mounts and/or any other critical structures)
with the airframe serial number clearly shown.
2. Clear color photos of tail plane construction prior to installation of the sheeting/skin (showing spars, ribs, shaft bearing blocks, anti-rotation hardware, hinge blocks (in the case of vertical fins or fixed stabilizers with hinged elevators) etc.)
3. Clear color photos of any area or apparatus that is considered a critical structure and is not visible to the end user without extraordinary inspection (such as cutting into closed structures)
It is understood that this requirement will add a small amount of time to your process,
so a nominal surcharge for the photo-documentation package should be established prior to the acceptance of the order by both parties. Please understand, however, that this photo-documentation needs to be of each individual model and not a batch, general sample, etc. The
purchaser needs to be furnished with the above-described
documentation for
the specific, individual model
with the unique airframe serial number clearly shown in the photo documentation. Again, this documentation shall be considered a necessary included component to the shipped model as much as a fuselage or wing is.
Note: A purchase agreement shall not be made unless this documentation is supplied with each kit or ARF, failure to supply the documentation package will result in a rejected shipment and a full refund of the purchasers funds.
