RCU Forums - View Single Post - 1st pull pull setup?
Old 12-14-2011 | 12:20 PM
Popriv
Default 1st pull pull setup?
I just bought a morris 3d profile plane with pull pull rudder and elevator ( so - do - somthin or other??? ). ( I'll put my OS .55 on it which is at the top end of its power rating)
I already installed the control horns on the elevator and rudder, the holes are about 1/32" behind the hinge line. ( is that ok? )
Any tips or things to watch out for on the pull pull set up?
Looks like one end just loops through the servo and has a single crimp. Just squish with plyers?
Should I but a drop of CA on the crimp? Its very thin cable with a plastic coating...
Does pull pull put any more strain on the servo? should they be ball bearing? nylon gears alright?
I plan on pulling 2 servos out of old equipment, is there a way to tell the condition of a servo?
Which servos would be the most critical?
throttle - used
rudder - used
elevator - buy new
aileron - buy 2 new
thanks
steve
