RE: Airplane rudder gyro
Hi:
I have this same gyro i bought fomr hobbyking (HK401B)
I have it installed in a Funtana 90 and have seent he video about 7 times and set it up to have the rate mode in low gain and heading hold is off..
Yet the problem i have is...
In rate mode the rudder twitches like crazy till you lift a bit the tail wheel from the floor.
And also the Limit is controlling how much travel the servo moves in the rudder.. this is a 3d plane so i need full deflection..
But when i tried the plaen in the air the tail starts to fish tail like crazy!!!!
I lowered the delay and still does the same.. i had to result to lower the limit and it has stopped it in a sense but now i don't have full deflection on the rudder ..
What am i doing wrong???
