RCU Forums - View Single Post - 1st pull pull setup?
Old 12-14-2011 | 06:49 PM
Popriv
Default RE: 1st pull pull setup?
Hey Billd76, thats great. let me know how you make out withthe maiden..
Yes its the same plane and engine. I've been flying a couple flat out 3d foamies and look forward to playing with this nitro plane....
Did your servo covers have the holes pre drilled? on the side with three servos mine is pre drilled with three hole all in a row but in the manual they show the holes stagered with the middle servo rotated 180 degrees.
I have 3 older servos, FP-S148, would these be ok to use or should I just spring for all new servos?
any pics?
good luck
steve
