RE: 1st pull pull setup?
As Bosarth says in post 10, the control horn and servo horns DO NOT have to be the same length. The same force arrangements hold as for push rod set ups, you can change the amount of throw by moving the attach points at either end to get other than a 1 to 1 throw, just do make sure that the set up does not bind up at full throw.
