RE: Glow plug prices
Generally, the more nitro, the faster you'll toast a plug.
If your engine has high enough compression to run 0% nitro and fly the airplane OK (power will be off some), the plugs will last longer, but you may need to switch to a hotter plug and tweak carb/idle setting with 0% nitro.
