ORIGINAL: NJRCFLYER2
Steve:
There's something else going on with Matt's 33GT. We even went to a different brand CDI unit it on the assumption that the stock CDI had some sort of minimum RPM code built into it. It really just acts like a fuel draw problem, my theory being that those 4 reeds need more negative pressure than a typical 2 reed setup, possibly because their individual surface areas are relatively small, though their combined surface area is probably larger than a comparable sized engine's 2 reed system. Matt's engine behaved well for the first 3 or 4 flights, then became a problem. We looked at various possibilities, leaks, warped reed block and the like, and it really didn't solve anything. It will be interesting to see what comes back from the repair.
Steve,
All of my trials and tribulations were covered in a letter to Hobbyservices. They should have my problems encountered in detail. Thanks for getting involved
