RE: RClander T33 for 90 or 120mm edf
The last modification I did to the cockpit was to give the dashboards an illusion of depth. I found a black plastic ring and cut several pieces out to glue around the decals. I used Aileen's Tacky White Glue on the canopy and then glued the tip tanks in place using BVM V-poxy. Both glues dry clear.
It was 25 degrees F outside this morning with some frost on the ground. I plan to do a taxi test video with some full power run-ups over the holiday break. The Lander 120mm DF sounds very nice in the T-33.
