RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 12-17-2011 | 11:46 AM
  #117
NJRCFLYER2
My Feedback: (42)
Default RE: OS 33GT Gasoline Engine for Pattern
ORIGINAL: speedracerntrixie
Matt, I appriciate you comments about the soft mount but as these will be used for IMAC competition I will contunue to hard mount. I have been hard mounting for 14 years now without any ill results.
Doesn't IMAC still have anoise score? Should be a slam-dunk 10 if you outfit your engine the way Matt describes. Plus, your servos will all last longer and you will use a lot less battery capacity each flight. Everything lasts longer, and amazingly, you get a little more usable power delivered to the prop. If you think about it, any energy that is not wasted on rattling the airframe and producing acoustic waves from the airframe is going somewhere else - into the prop!
